Business Plan II 10 years 8 months ago #1923
@Giovanni Ciavarelli : I like it B)
The following user(s) said Thank You: Giovanni Ciavarelli
Business Plan II 10 years 8 months ago #2084
  • Seele Design
  • Seele Design's Avatar
Hello, I installed the template business and I would like the presets 4 but I find it difficult to change because in doing "save" command is blocked and does not save anything, if I use the same form scroller, even here you can not change the settings because the "save" function not
Thank You
sviluppo.arisecentrolistico.it/
Business Plan II 10 years 8 months ago #2085
Thank You
Ciao!
Take a look here!
vinagecko.com/forum/free-joomla-template...an-ii?start=102#1920
and you will solve your problem in less than 5 minutes! :)
Business Plan II 10 years 8 months ago #2086
  • Seele Design
it works! thank you!!!
Error loading some Business Plan II file configurations 10 years 8 months ago #2089
  • Juvencio Come
  • Juvencio Come's Avatar
Hi! I installed my Business Plan II quickstart in localhost, but when I transfer it to the remote server, the frontend return the following error: load error: "failed to find C:\wamp\www\consultores\templates/business_plan_ii/less/master.less
Go Back Home"
I think that I have to change the url configuration somewhere, but I cant find the file where I must do this. Help me finding the respective file where I've do change the url in order to point the new server, please!
You can see the error here: rlccmoz.com/demo
Thank you
Sorry for my English, I can't speak neither write it well.
Last Edit: 10 years 8 months ago by Juvencio Come.
Error loading some Business Plan II file configurations 10 years 8 months ago #2094
Hello Juvencio Come,
Please make sure that your folder are writtable.
And just clean cache from your joomla admin will solve the issue.
The following user(s) said Thank You: Juvencio Come
