Business Plan II 10 years 8 months ago #1737
@Tamara: You need duplicate template, and assign template for each language.
And then you can select the main menu for each language in each template.
Please follow this to see more details:
Last Edit: 10 years 8 months ago by Rango.
Business Plan II 10 years 8 months ago #1739
  • Tamara
  • Tamara's Avatar
@Rango: Thank you for reply! I see you wanted to write a link in the end of a message, but you didn't. Could you please share it? Thank you in advance! Best wishes!
Business Plan II Joomla Update 10 years 7 months ago #1904
  • bobby
  • bobby's Avatar
Hello i am trying to setup my website with the Blue Design II templates but when i update the joomla to the latest version i cant change the templates settings anymore i tried on two different websites ( test and good one ) but it does the same thing as soon as i update the joomla to 3.4.2. the template section save button stops working
An other thing how can i make the top menu ( main menu ) start a little closer to the logo so i could add some more main menu because it sends them down and it does not look nice ..
How to activate the Helix short code .. when i try it doesnt show me the animation it just shows me the code on the frontpage
or it says : /javascript:; was not found on this server.
Need help
Business Plan II 10 years 7 months ago #1905
  • bobby
  • bobby's Avatar
Need help
Business Plan II 10 years 7 months ago #1915
@bobby :
I think it is problem with Helix Shortcode plugin. It's not yet compatible with Joomla 3.4.2.
We need to wait JoomShaper fix this problem.
Last Edit: 10 years 7 months ago by Cuộc Sống Số.
Business Plan II 10 years 7 months ago #1920
There is a fix for this in Joomshaper forum... before the offical update you can do this trick:
go to 'plugins\system\helix\js\admin\layout.admin.js' on 143 no line just remove ' return false;'
Or if you are not so fond with editors just replace that file with this I put on attachment
It worked for me but not in Chrome. I tested with firefox and It worked.... better than nothing!
By the way ... DO A BACKUP COPY of the file, before you change it ... In Attachment there is also the ORIGINAL FILE.
Then clear Joomla and browser cache and have a try! :-)
Last Edit: 10 years 7 months ago by Giovanni Ciavarelli.
The following user(s) said Thank You: Cuộc Sống Số, Alfred
