Business Template ii Menu Problem 10 years 10 months ago #1717
  • corey
  • corey's Avatar
Hi Guys,
Firstly, Thanks for this wonderful template. It is the best responsive template I have used.
Let me also say that my webdevelopment knowledge is also limited. I have a problem with the Main Menu display. I can't seem to get it to work in Internet Explorer 9. I know this is old but most of the company's internal users will be using this as it is critical to other web applications in use. If I use the default position as "menu" in the layouts tab of business ii, it uses a totally different style as the menu appears horizontal in firefox and vertical in I.E. So I have to select another menu item to use; mainmenu or another menu as the selected position. In this case, I have no role over drop down menu. The submenu list just appears under each menu item. I can hide it or show it; no real drop down effect. In the other menus I have set the menu class suffix to nav-pills. An example is below in the image. The Directory List and Search are two sub-menus.
Any help is appreciated.
Thank you.
Last Edit: 10 years 10 months ago by corey.
Business Plan II 10 years 10 months ago #1719
  • corey
  • corey's Avatar
HI Guys,
This template is really great. Huge thank you to the developers and other people who assisted.
Can anyone tell me how to increase the spacing between rows in a module? I find for example that the titles of the bottom modules are very close to the end of the top module.
Business Plan II 10 years 10 months ago #1720
corey wrote:
HI Guys,
Hi!
This is not The right solution but you may use a custom html with <br> tag and put it where you need more space. Of course set The title off!!
Business Plan II 10 years 10 months ago #1721
  • corey
  • corey's Avatar
Thanks for your assistance.
I had already tried it earlier without the tag. With the tag it's better.
Thanks Again.
Business Plan II 10 years 10 months ago #1722
  • corey
  • corey's Avatar
I had posted the below query in the General Area, not realising that I should probably have posted this here. I apologise for double posting and would remove the previous post if I could. I would like some assistance if possible. Thank you.
Hi Guys,
Thank you.
Business Plan II 10 years 10 months ago #1734
  • Tamara
  • Tamara's Avatar
Hello.
I have to say the template is great, but I have a problem concernig the languages. Anyway, my site has to be shown in English and one more language, and when I choose the main menu in the template, it will not change into the another language when I change language of a site. I am not sure if you understood my problem. The menu cannot change when I change a language of a site... it shows the same menu regardless of the language I choose...
Last Edit: 10 years 10 months ago by Tamara. Reason: bad explanation...
