Business Plan II 10 years 7 months ago #2247
Hello can,
You need read document : docs.joomla3.info/template/business_plan/
If you Install Template you missed step Install plugin Helix system
Check : http://docs.joomla3.info/template/business_plan/#install-template
Last Edit: 10 years 4 months ago by Cuộc Sống Số.
Changing font Main menu font size 10 years 5 months ago #2570
  • Faith Simon
  • Faith Simon's Avatar
I have created my company website using Business Plan II template. I have many items in the main menu(top menu) that they fall on two lines.
Please help how do I change menu case to lower case and decrease the font size so that the main menu fits within one line?
Your prompt response will highly be appreciated.
Faith
Business plan 2 How to remove main menu from certain pages 10 years 5 months ago #2571
  • Brian
  • Brian's Avatar
Hi How can I remove the main menu from certain pages, tried looking in modules but can't find the main menu
Business plan 2 How to remove main menu from certain pages 10 years 5 months ago #2575
@Faith Simon: You can change menu case to lower case and reduce the font size by change css code in this file:
ROOT/templates/business_plan_ii/less/menu.less (check my attachment to see more details)
@Brian: The main menu is not a module. It's a path of the template. However, You can clone template and remove menu position then assign new template for each page you want.
Last Edit: 10 years 5 months ago by Rango.
The following user(s) said Thank You: Brian, Faith Simon
Business Plan II 10 years 5 months ago #2670
  • Godwin
  • Godwin's Avatar
please i have a problem with Business Plan II. I successfully installed it locally on my xampp. after making changes of the slogan logo etc. it cannot save?
Can i know what the problem is?
I have tried another template to see and it saved. but Business Plan II is not saving.
Business Plan II 10 years 4 months ago #2681
Hello Godwin,
You can try install Helix Plugin v2.2. Download at here : joomla.vinagecko.net/d/t/helix/plg_system_helix_j25_j3.zip
