Remove Sidebar 11 years 6 months ago #482
Dear Vision Integrations,
The left sidebar show Joomla Modules, it's not inside article.
If you want hide it, you should disable modules on the page you want to remove them.
Business Plan II 11 years 6 months ago #483
  • Kumar Wani
  • Kumar Wani's Avatar
Dear sir, Thank you for providing business plan ii. I have installed the theme package with demo content, site's main menu's are renamed with my requirement and selected proper articles for each page. On Joomla administration panel everything is available for edit and update all pages are published. Now update the content of article templates..Thank you again for your support.
my site url : www.magnuspublishing.com
regards, KW
Business Plan II 11 years 6 months ago #493
  • Kumar Wani
Dear sir,
After successful installation of Business Plan_II while updating the content on contact page it got disturbed, please guide me how to set up the page as in demo. Also how to configure the contact form so that if any visitor fills in the form i get email notification?
More info about the issue: I didn't change the shortcode just removed demo content tried to delete blank space and add new text and it all got disturbed as in the attached image file. please see this link directly: www.magnuspublishing.com/contact.html
Business Plan II 11 years 6 months ago #494
Hello Kumar Wani,
1. You can configure the contact form through module is located "contact":
- You can read more at here : http://www.ql.de/index.php/joomla/joomla-downloads/mod-qlform/doc
2. To edit the "Contact Us" easily, you do the following:
I hope the above will help you ;)
The following user(s) said Thank You: Rango, Kumar Wani
Business Plan II 11 years 6 months ago #503
  • Kumar Wani
Dear sir, Thank you for supplying the code for setting up the contact form as in the demo. I did type and it was all set up. Regarding the notification of visitors message I think I'm missing something. I mean if some visitor fills in the message I'm not getting the alert on my email. Will you please give me details how to configure it.
1. I have added downloadable pdf links in the article via media manager, is it the correct way to do that? or there is any other way to link downloadable pdf in article text?
2. Also I want that the pdf which linked for download should be downloaded by registered users only, how to do that? (if unregistered user tries to download pdf, it should display the message "You should registered to view/download this file")
3. RSS feed is the issue which I wish you could help to configure?
4. How to create new article which will automatically be added to the blog list (recent article)?
5. Configuring newlsetter is also a problem for me because it is custom html when I go to module section to update/configure it, but could do nothing about that? Please help.
I will be very thank ful if you help
Business Plan II 11 years 6 months ago #504
Dear Kumar Wani,
We're sorry. But we can't answer all your question, because it does not regards our template.
I think you need to learn more about Joomla. Or find some developer to help you build your website.
We only can support problem with our template (install, config template, fix bug with template).
The following user(s) said Thank You: Kumar Wani
