Business Plan II 11 years 3 months ago #712
  • maad
  • maad's Avatar
  • Thank you received: 2
I made my company website with very nice Business Plan II template.
I had to change font from YanoneKaffeesatz to another one from google fonts, because Yanone improper display some characters in my language.
It's work fine, the new font is correct, but there is a problem with file template.css. When I make backup using akeeba and restore whole site in another place, this file magically losses all modifications I've done.
What's going on? Is this problem with akeeba backup? Maybe I'm not allowed to modify your's template?
Please help me :) and sorry for my English ;)
Maad
Business Plan II 11 years 3 months ago #717
Dear Maad,
Your language is good. Don't worry about that.
Our template using LESS CSS, so if you want to modify css, you must change in LESS files (in folder business_plan/less/)
If you don't know LESS CSS, you can disable it to use normal css by set value of param LESS = No
Business Plan II 11 years 3 months ago #718
  • maad
  • maad's Avatar
Rango, thank you very much for your help :)
I've looked into LESS folder and made some changes. I left LESS switch on.
Now everything works ok. The site look delicious, in my humble opinion of course ;)
This is my lovely child: www.hax.com.pl
I'm very happy with joomla, with vinagecko and all the people around the world ...except Putin
have a nice weekend
best regards
Marek
The following user(s) said Thank You: Rango, Cuộc Sống Số
Business Plan II 11 years 3 months ago #720
  • Godwin
  • Godwin's Avatar
i must say that the Business Template II is a wonderful template. I have issue on viewing it on mobile as it does not indicate the main menu. It only shows a long bar and except you mistakenly
click on it you wont know its the main menu is hidden there. How can this be corrected so that users can know its a menu chunk there. Expecting your kind reply.
Business Plan II 11 years 3 months ago #721
Dear Godwin,
Please check my screenshot. I think everyone know that is menu icon (Facebook is also use icon like that too)
However, you can change it to other icon or use text (Eg: Menu) if you want.
Business Plan II 11 years 3 months ago #722
  • Godwin
  • Godwin's Avatar
Thanks for ur response. i cant see it show like that as in ur scrern shot.
How can i change it to Text or Icon as you said.
