Business Plan II 11 years 4 months ago #506
  • Kumar Wani
  • Kumar Wani's Avatar
Dear sir,
I am sorry for causing inconvenience by asking questions on wrong platform. Thank you for your suggestion. I have talked to the local developer regarding specific issues raised here. Thank you for your real time support. Next time I will ask only those problems which are related to the template, config, and bug if any. By the way, may I ask, will updating akeeba backup affect the template in anyway (I mean akeeba update should not disturb template in any way)? If this query comes within your scope please give a word. Thank you for SUPPORT.
Regards,
KW
Business Plan II 11 years 4 months ago #507
Hello Kumar Wani,
No problem, you can update Akeeba, Joomla as well. Just don't forget backup before do it.
Business plan 2 add module 11 years 3 months ago #655
  • Brian
  • Brian's Avatar
Hi I've duplicated a module but it does not show correctly on the home screen it's as if it needs more space and the footer and partners area is in the way.
Can I move these two areas down. I've tried looking in template layout but can't see any thing obvious
this is the url 192.185.4.48/~ajames/
Last Edit: 11 years 3 months ago by Brian. Reason: add url
Business plan 2 add module 11 years 3 months ago #661
Dear Brian,
Could you please give me more details about your problem?
I've checked your page and don't know what is the problem there.
Business plan 2 add module 11 years 3 months ago #663
  • Brian
  • Brian's Avatar
On the home page under Our Services there are 3 images with text and read more
The seecond set of images should also have text and read more but it is under the footer
Business plan 2 add module 11 years 3 months ago #666
Dear Brian,
I think you're wrong to config the Height of this module. Please check and set correct value, then you will see how it work.
(The height of module when you display all title, description should be more than 350px)
The following user(s) said Thank You: Brian
