TOPIC: Vina Rubbez
Mega Menu Help? 10 years 6 months ago #2416
  • Florence Davis
  • Florence Davis's Avatar
Hi Rango, thanks for your reply. The video you so kindly posted is helpful for dragging and dropping modules. But I'm trying to create a menu with links to Virtue Mart categories and products, JoomShaper pages, Articles, and iWrapper menu items, etc. (not modules)
I'm trying to make the links into 3 columns. I'm practicing by making a parent menu item with 3 child menu items. To start, just to keep it simple, I created them all as external links with # for the link URL (screenshot).
In the parent item, I chose the 3 column layout in the mega menu options. The tutorials online make it look like this should automatically sort the (1st generation) child menu items into 3 columns. But it isn't working, and all 3 child items are still in one column under the parent (screenshot).
Can anyone advise how to sort links that are not modules (like the ones in my screenshots) into 3 columns?
Thanks again
Last Edit: 10 years 6 months ago by Florence Davis.
Mega Menu Help? 10 years 6 months ago #2420
Hi Florence Davis,
You need create Menu item child for child 1, child 2, child 3.
And click Reset :
The following user(s) said Thank You: Florence Davis
Mega Menu Help? 10 years 6 months ago #2429
  • Florence Davis
Ah! Thank you so much! I tried creating 3rd generation links (test 11 and test 211) after posting my message, and it didn't work. That's because I didn't think to click the reset button.
Worked perfectly. Thank you! B)
Vina Rubbez 10 years 5 months ago #2451
  • Florence Davis
Hi! I'm still working on my website, and have a (hopefully) simple question.
I'm modifying the page that came with the Rubbez template "Our Services". Part of the page is a bunch of Feature Boxes with "Our Core Features".
Each has a round circle-shaped button with icon inside. When you hover over it, the cursor changes into a hand and the circle changes from an outline to solid (filled), indicating a link. In the template, the link doesn't actually do anything. I'm trying to change that and insert an actual link url, but cannot find where I can do that.
I've looked quite a bit, without success yet. So, I"m hoping this is just a quick question easily answered. I've attached a screenshot.
Thanks in advance for any replies.
Last Edit: 10 years 5 months ago by Florence Davis.
Vina Rubbez 10 years 5 months ago #2453
@Florence Davis: It's a add-on of SP Page Builder. We can't add the link for the icons.
Vina Rubbez 10 years 5 months ago #2458
  • Florence Davis
Oh....too bad. Thanks again for your help!
