TOPIC: Vina Rubbez
Vina Rubbez 10 years 5 months ago #2596
  • Florence Davis
  • Florence Davis's Avatar
Hello, I am using the Rubbez template. On mobile phones, the off-canvas menu icon is showing, but it is not a link. When you hover over it, nothing happens. I checked the Off-Canvas Menu module, the template documentation, and did a Google search, but cannot find an answer to this problem. Can anyone please advise how to make the off-canvas menu work?
Thank you!
PS My website is suddenstorm.org
PPS, please let me know if I should submit this question via a support ticket instead, with proof of purchase etc.. Thanks!
Vina Rubbez 10 years 4 months ago #2598
Hello Florence Davis,
I understand the issue. You need to submit ticket at tickets.vinagecko.com/ , I will help you solve it
The following user(s) said Thank You: Florence Davis
Vina Rubbez 10 years 4 months ago #2603
  • Florence Davis
Thank you, I will do that.
Vina Rubbez 9 years 9 months ago #3488
  • Valerii
  • Valerii's Avatar
Hi, just purchased this teampalate, is there an option to upgrade Joomla and php to version 7?
For now i get
Fatal error: Cannot use Joomla\String\String as String because 'String' is a special class name in /home/vsport/vsport.com.ua/www/libraries/vendor/joomla/registry/src/Format/Json.php on line 12
Vina Rubbez 9 years 9 months ago #3493
@Valerii: It's problem with Joomla, you need update your website to Joomla 3.5.x:
forum.joomla.org/viewtopic.php?t=903202
issues.joomla.org/tracker/joomla-cms/7571
