Business Plan II 9 years 9 months ago #3640
Sorry, one further question. I plan on customising the business plan II template by changing the templates CSS files. I have read this isn't how you do it with Helix II. If I was to change the CSS and update Joomla and Helix in the future will I lose my changed?
Many thanks in advance for your time.
Business Plan II 9 years 9 months ago #3644
  • Chung Pham
  • Chung Pham's Avatar
  • Personal Text
  • Thank you received: 11
you have add css in file custom.css
when you update joomla it will not changing
Chung Pham
The following user(s) said Thank You: Richard Luscombe
Business Plan II 9 years 9 months ago #3645
  • Chung Pham
  • Personal Text
@Richard Luscombe when used the Helix framework you can use any standard Joomla extensions, you can adding multiple image galleries and don't restricted.
Chung Pham
Last Edit: 9 years 9 months ago by Chung Pham.
Business Plan II 9 years 8 months ago #3650
Hello. I have installed everything on my server using Akeeba and everything works fine apart from the image slider. I am getting the module area showing with a revolving circle and the 3 dots showing how many slides there should be but it is not picking up the images. (see attached file.) The slider files are in the folder slideshow and the individual files are named 1.jpg etc as with the demo.
Many thanks for your help in advance.
Business Plan II 9 years 8 months ago #3651
Further to my message. The images do appear when I turn off Resize Image but then I am not in control of my image sizes. I am using Joomla version 3.5 and have installed the latest version of the slider and am not suing the version that came with the template set-up.
Kind regards.
Business Plan II 9 years 8 months ago #3653
  • Chung Pham
  • Personal Text
@Richard Luscombe
I think you're wrong path image, you change the image path
Chung Pham
