Business Plan II 10 years 2 weeks ago #3280
  • Ahmet YILMAZ
  • Ahmet YILMAZ's Avatar
K2 Process Problem
K2, also a new record, edit article or as a result of any action;
This site is unreachable.
The connection was reset.
ERR_CONNECTION_RESET
Coming error and white page. On the other hand Joomla's running smoothly all the components. K2 works fine on localhost.
Thank you for your help ...
www.redklaus.com
Joomla 3.4.8
K2 v2.6.9
MySQL 5.6.29
PHP Version 5.5.28
Error installing template 9 years 10 months ago #3447
  • kibernet
  • kibernet's Avatar
@Marco: I think you are forget to install/active Helix Framework. Please read the document and follow it to install/config template and modules.
Where is the documentation?
docs.vinagecko.com/?template=business_plan
is unavailable.
Error installing template 9 years 10 months ago #3458
@kibernet,
Link document for you : joomla.vinagecko.net/d/t/business_plan/
Business Plan II 9 years 9 months ago #3636
Hello. The Business Plan II template is superb! I have one simple question. Is it possible to remove the large black strip at the bottom with the copyright info? I would happily pay to have this removed from my site. The copyright bar is a lot larger and more prominent than most I have seen with the large Helix logo.
Many thanks in advance.
Business Plan II 9 years 9 months ago #3638
  • Chung Pham
  • Chung Pham's Avatar
  • Personal Text
  • Thank you received: 11
You need purchase template copyright removal service here: vinagecko.com/copyright-removal After that, please submit a ticket here: tickets.vinagecko.com/ our support team will help you remove copyright bar as you want.
Chung Pham
The following user(s) said Thank You: Richard Luscombe
Business Plan II 9 years 9 months ago #3639
Many thanks for your response :-) May I just also ask. Does the template work with Helix 3 or does it have to be Helix 2? I am assuming there is still full support for Helix 2? Having never used the Helix framework can I use any standard Joomla extensions or do they have to be specifically compatible with Helix? I am adding multiple image galleries and don't want to be restricted. Finally, I am building the website on my own server and will need to transfer the website to the live server once it is built. Would I do this the same way I would any other website or would I need Akeeba again?
