TOPIC: Vina Camera Slider for K2
Vina Camera Slider for K2 11 years 6 months ago #348
  • Hieu Ja
  • Hieu Ja's Avatar
  • Thank you received: 18
Vina Camera Slider for K2 is a free module for Joomla 3.x to display Items of K2 Component in responsive slider with many features: 30 Transition Effects, 32 Skin Types to Set, easy to control items to display... It uses a light version of jQuery mobile, you can navigate the slides by swiping with your fingers. Being compatible with most of the browsers Vina Camera Slider for K2 is a perfect choice to display items of K2 Component in responsive slideshow. Have an easy to control the module displaying via simple parameters, you can do everything as you like and let your client see your site in a impression way.
See how you can bring your site to the next level.
Main Features:
- Retrieve items from one or more categories / or select specific items.
- Allow to sort order by: Recently Added/Recently Modified/ Ordering/Title or Random.
- 30 Transition Effects: Vina Camera Slider for K2 offers 30 eye-catching transition effects to impress your visitors with stunning animations.
- 32 Skin Types to Set: Easy to change module style to fit with style your website.
- Automatic Image Sizing: Images are automatically cropped and resized which makes publishing slideshow as easy as pie!
- Thumbnail Images Navigation: Vina Camera Slider for K2 will auto create thumbnail images and make it work as a navigation.
- Infinitely looping: Loop through your slides endlessly in both directions.
- Fully Responsive: Vina Camera Slider for K2 respond perfectly for all device resolutions like mobiles, tablets and the browser size of your site visitor.
- Mobile Device Optimized: Vina Camera Slider for K2 works on any javascript enabled browser, including Windows Phone, iOS, Android and Opera Mobile etc.
- Cross Browser, All Browsers Supported: Vina Camera Slider for K2 is cross browser slider, all browsers are supported (IE 8+, Firefox 2+, Chrome 3+, Safari 3+, Opera 10+, iOS Safari, Opera Mobile, Android Browser, iPhone, iPad, Mac, Windows Surface etc.).
- Support Multi-Language; Support Multi-Module in the same page.
- Totally customizable and skinnable using HTML and CSS. To manipulate almost everything!
Module require:
- Joomla v3.2.3 or later.
- K2 v2.5.6 or later.
Useful Links: Download - Demo - Documentation
Vina Camera Slider for K2 11 years 5 months ago #455
  • milorad
  • milorad's Avatar
Dear,
I have problem with showing title in Vina Camera Slider for K2, can you please explain me how to change title color in module?
Check the photo.
Thank you.
Vina Camera Slider for K2 11 years 5 months ago #461
Dear Milorad,
This module get default color of H3 tag from your template. If you want to change it, you need write css code to override it.
Just give me URL to your site, and color you want to use, i will give you the code.
Vina Camera Slider for K2 11 years 5 months ago #465
  • milorad
  • milorad's Avatar
Dear Rango,
I tried in CSS code but it didn't worked. This is URL - www.bl-portal.com, and I would like 'WHITE' color (#FFFFFF).
Thanks a lot. :)
Vina Camera Slider for K2 11 years 5 months ago #466
Dear Milorad,
I can't connect to your website. I've got message: The server at www.bl-portal.com is taking too long to respond.
However, please try open this file: modules/mod_vina_camera_slider_k2/assets/camera.css then add this in the end of this file:
.vina-camera-slider-k2 .camera_caption > div h3 {
     color: #FFFFFF;
Please try add this code and refresh your page then check again.
PS: you also can add this code to css file of your template, then you don't need add this again when you update new version of this module.
Vina Camera Slider for K2 11 years 5 months ago #467
  • milorad
  • milorad's Avatar
Dear Rango,
I'm sorry, i tried and it didn't worked again. Can you please send me complete changed CSS code (file), I will upload it in cPanel.
